Help
Discussion in 'Civic and CRX - EF' started by lilsutton, Mar 11, 2009.
  1. lilsutton
    lilsutton New Member
    i just got me a 1987 crx hf and i want to but a better engine in it.
    what should i but in it?
  2. Brujo13
    Brujo13 New Member
    well i guess it depends on what you want
    how much power are you looking to get?
    is $$$ an issue?
    maybe you should consider a Mini-me head swap, but im not sure on how that would work with the 87
    anyway im new so im not very informed yet, im usre some other people here can help you with some recomendations
    also google crx engine swaps lot of good info floating around
  3. Stleger184634
    Stleger184634 New Member
    Maine
    yah the mini swaps are sweet that would be my first suggestion for you especially if you dont want to spend alot of money on it you can usually pick up the complete swap from tigerjapanese.com or h-motors. Since you can get the whole set up for 600-800 depending on who you go through you jsut have to make sure that you get the right tranny for you year i would suggest the si cable tranny, its the shortest tranny and it is awesome for your year crx. good luck =)
  4. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    stupid greenhorns. you might wanna ask B for this thread to be put in the right catigory or it might get closed.
  5. OGMatt
    vic B.C. Japanada
    anyway there is not many options with the EW's. I have seen people but b16's into them but with maga fabrication. also look into doing some NA stuff like cams and valves.
