help!!
str8jdmda
hey guys my car hasent ran for probably 4 months and im starting to run out of thing to check and replace so my question is, is there anyway to tell if ur dizzy is messed up or should i just try another 1 to see if anything happens.. my cars throwing a colde 43 and it sounds liek its bogging liek crazy and running liek hella rich im gonan check my timming in the next few days but if you have any suggestions please let me know by the way the car is all stock..
-thanks-
so it runs just runs real rich? id check the timming, check ur belt maby it is slippin, and MABY iv heard it is rare but ur injectors might be shot and pulse wrong. good luck bro.
Tyler
If your timing belt was "slipping" you would know it.... bent valves and broken stuff. Sounds like maybe your timing but without knowing what you have replaced, and what your setup is it is hard to tell. More info is needed.
