Help!
Discussion in 'HYBRID -> ED-EF / DA' started by racingtopher, May 28, 2004.
  1. racingtopher
    racingtopher Member
    I am having problems with my b16a
    I have a 91 civic EX 4dr
    It has a 2nd gen b16 from the 93 integra Xsi (obd 1)
    Using a d16a6 harness spliced with the b16 (injector plugs etc.)
    I am running a pr3 obd 1 ecu
    I bought new cap, rotor, spark plugs, wires, IACV, battery (relocated to trunk)
    on a cold start the car runs fine, but once it is warmed up and it is shut off, when you try to start it up again it idles at 200 rpms or not at all. at regular idle it idles at 1100-1300 rpms an i know its suposed to be at like 800.
    Engine light stays on ever since the swap, dont know why.
    Is it a problem to be running a single wire o2 if the ecu uses a 3 wire one?
    thanks
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    Well...if the engine light is on, you're thowing a code. Which means: pull the code. There's an FAQ on how to do it in the articles section or something. Find the light on your ecu and count the long flashes, those are the 10's digets, then count the short flashes, those are the 1's digets. So long, long, long, short, short would = 32.
    [edit] yes you need to splice in the wires for the 3 wire O2 sensor. It is manditory for OBD1[/edit]
  3. racingtopher
    racingtopher Member
    my ecu does not have a code light like my old pm6 (obd0) one.
    i think i would need the obd 1 dash harness to get codes.
    where do the four wires go on the ecu?
  4. brian11to1
    brian11to1 Senior Member
    Id wire the car OBD0... but thats just me.
  5. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    If I remember right my old `92 civic was obd1 and I had to jumper two pins under the dash near the computer and then the cel would blink on the dash. But with a swap like that I am not sure which wires you would then jump.
  6. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    Read The Damn Article! B wrote it for a reason, he tells you the wire colors and everything
