help
Discussion in 'General Tech and Maintenance' started by bigharp_civic, Oct 30, 2006.
  1. bigharp_civic
    bigharp_civic New Member
    ok i have a 95 honda civic and i cant figure out why it is buring oil so bad like it is, every time i check the pcv valve it has oil guncked up through it i have replaced it 3 times and it keeps getting clogged, the rings r pretty good that i know of, it has good compression up around 125 for all 4, it burned alot of oil when i had my z6 head on but then i put a y8 head on and it worked ok for a little bit but now it is burning oil again and it is only when u go over 2500 rpm
