HELPPP
Discussion in 'General Tech and Maintenance' started by str8jdmda, Jun 3, 2004.
  1. str8jdmda
    str8jdmda Junior Member
    ok well 3 of my wheel studs broke when i was tryin to take them off and i went and bought 4 new 1's with lug nuts and attemped to put them in, and now im stuck do i need to get the hub pressed out in order to get the studs in or can i just use a hammer or what? any help will be greatly appreicated thanx-clint
  2. ahedau
    ahedau Senior Member
    Middle GA
    put a nut over the stud then put your lug over the nut. Tighten the lug nut down and it will pull the stud through the hub.
    If you don't have a torque wretch, buy one.. No more than 85 ft/lbs to tighten the lugs!!!
    and oh, yeah.....rightie-tightie, leftie-loosey
  3. str8jdmda
    sorry maybe i should have said it a lil better i cant get the old broken ones out.
  4. Arachnid
    Arachnid Senior Member
    all i did when mines broke was hit it with a hammer until it came out. but for the new one to go in, i used a rubber hammer( fucked up the hammer). you'll have to improvise!!!
