roadracer321
Member
Well, I have done A LOT of research on this for months and months, but I cannot figure this out now. I have saved a bunch of articles on here, including a really good by 92B16VX "How To Wire VTEC" , but it doesnt apply to me because of different color wires.
So here is what I have going on. As you can see, I have the SiR-G motor going into a 92 Civic HB
Supposively the VTEC wires are run from the cannon plugs to the ECU, but I dont know what colors they are? There are two colors that I found that dont go to the engine, but are run to the cannon plug. Those two colors are org/wht and org/blu. Anyone know what these are? The article I read said the VTEC wires were yellow with some stripe colors on there. I dont have them. The colors I have are:
red/yel
red/wht
pink
lt grn
grn/wht
yel/white (this continues to go to the engine)
red/grn
org/blu
wht/yel
org/blk
org/wht
I have both Haynes manuals for the 92 Civic and the 94+ Integra, but the colors are not accurate for the integra. I dont know if this is due to the fact that it is a JDM engine. I am having trouble finding the VTEC pressure plug, I believe this is suppose to be a blue and black wire? Well, I cant find it.
The knock sensor is another question. When I took it apart, I noticed there was a silver braided wire attached to it that I just cut off. Was that important to my wiring, or do I just run that red/blu wire to the ECU?
Next is the IAB sensor. What the hell does this plug into? Where does it go? I found the pinouts for this, I hope this is accurate. I am going to be using the OBD1 p72 ECU. Does this get run directly to the ECU or to a cannon plug?
Another thing, I have the Purge Control Solenoid and Electric Air Control Valve Solenoid. What do I do with these? I dont see these on my wiring diagram for the GSR motor.
Thats all I can think of right now, all help with this would be greatly appriciated!!!
I have looked all over for these answers before posting this.
red/yel
red/wht
pink
lt grn
grn/wht
red/grn
org/blu
wht/yel
org/blk
org/wht
