Here we go again!
Discussion in 'General Tech and Maintenance' started by vtecjdm, Aug 6, 2005.
  1. vtecjdm
    vtecjdm Senior Member
    hey guys i know this sounds strange to ask but is there a way to check the ignitor and coil inside the dizzy just buy using its plugs .. ?
    ie: instead of removing the dizzy cap and rotor... ?
    why u may ask ? .. well cause the rotor screw is jamed !
    I`m stuck now .. its eaither i get a new dizzy or i donno actually if it is the dizzy
    Was about to do the normal helms ignition test but cant reach the wires with the dizzy cap on ! helppp
    Anyone ? :worthy:
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    I had a problem with this yesterday, i just scraped off the plastic part of the rotor, under the dist cap, then used vice grips to get the screw out, then used a dremel to "etch" enough so that i could use a screw driver to get the screw back in.
    EDIT: i did all of this with the distibutor removed from the engine and in the garage.
  3. vtecjdm
    Heh thought i`d use a more conventional method than half destroying the cover ..
    So there is no way to check the dizzy internals JUST from the plug ends with a multimeter it seems .. right ?
    Btw, i got oil comin inside the dizzy(from the inside of the housing) .. had relpaced the cam o-ring and am 101% sure the oil is getting in from the inside and i guess thats what ruing the components.
    Is ther any seal inside that can be replaced ? .. when i had removed the cap looong ago i couldnt see any other seals .. :blink:
  4. vtecjdm
    I know sounds basic but how do you check if you got spark without using a spark tester ?
