Heres my setup: should I go vafc or hondata?
Discussion in 'General Tech and Maintenance' started by BigBoy, Jun 27, 2005.
  1. BigBoy
    BigBoy Senior Member
    cali 818
    Im lookin to do an all motor setup and want to do some tuning. Just debating whether it will be worth it to switch to obd1 hondata or not.
    JDM B16A
    2.5 CAI
    JDM DC 4-1 Header
    Apexi ws 60mm catback
    Skunk2 stage 2 cams
    Skunk2 valve springs
    Skunk2 cam gears
    AEM fuel rail
    B&M fuel pressure regulator
    MSG fuel pressure gauge
    MSD 6A-L discharge
    MSD Pro cap
    MSD Blaster 2 coil and wire
    Accel 8.8 mm spark plug wires
    Ngk laser platinum spark plugs
    MSD 9000 rpm pill
    Dynoed without tuning 160 whp 117 tq
    planning on getting an aebs tb, rmf header, and maybe some head porting.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    For that setup, definitely Hondata > VAFC.
  3. b16coupe
    b16coupe Senior Member
    anderson, S.C.
    :werd:
    or possibly uberdata
    I'm not sure but I bet with thoes cams you would benefit more with higher compression.
  4. sohcslammer
    sohcslammer Senior Member
    Bay Area
    Abso-fuckin'-lutly. You are way over cammed right now.
    And I don't totaly agree with these guys either, even though Hondata is a way better tuning device over all, the vafc will not blow your motor up, you most likely wont see any more peak wheel power from the Hondata, and converting to OBD1 can be costly and is often illegal in most states. If you are already OBD1 then of course, Hondata or Uberdata would be the obvious choice. But for OBD2 cars I recomend the AEM EMS. Granted, it's not cheap, but it's all you will ever need even if you decide to go FI later in the future...
    Just my .02 cents
  5. BigBoy
    cali 818
    Its obd0 pr3 ecu. Ive decided to go hondata, but its alot more expensive. Hope its worth it.
  6. ryan89crx
    ryan89crx Senior Member
    Washington State
    id say Uber or Crome, cheaper than Hondata
  7. formby
    formby learning in progress
    also turbo edit is cool....and get an osrtrich....from moates.net.....it lets you make changes on the fly and no need to burn chips
  8. BigBoy
    cali 818
    I heard turboedit doesnt support vtec?
    For unber, honata, etc i would need to convert to obd1.
    If i do hondata along with the conversion it'll run me about 1000
    The vafc for $200 is looking very tempting now. Will i see much more of a gain from hondata, uber, crome, than the vafc?
  9. ryan89crx
    Washington State
    sure does, it uses the a/c switch to activate it.
  10. formby
    wtf....yes turbo edit is like a free version of hondata...it supports everything you need to tune you ecu...all the parts you need will cost you around 250...if you buy the ostrich
  11. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Get a socketed pm6, turboedit, and the NG55(?) bin, and modify it to your liking on an ostrich or romulator, as turboedit supports both chip emulators. I'd also recommend the datalogging mod from gotspeed.com
  12. hybrid89
    hybrid89 thistownsucks...
    SoCal
    If you are interested, I have an older (but brand new) Hondata 4b. fully loaded. It was the previous version right before the s200 setup came out, but it is made for OBD 0 setups. I have now converted to OBD 1 and this does me no good. brand new in the box, never installed. hit me up if you are interested.
    matt
  13. sohcslammer
    Bay Area
    What don't you have? :p
  14. ryan89crx
    Washington State
    NG60 is the current ROM
  15. hybrid89
    SoCal
    my damn hatch running!
  16. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    Since you only mentioned a VAFC or Hondata I will say go with Hondata, sorry Shadney I think that AEM EMS is too expensive and not necessary for this guys setup. Just my .02
  17. pissedoffsol
    crome pro > *
    go to obd1, and get crome pro. its worth it. puts to shame ubercraper, and is way more versitle than honcrapa
  18. MikeBergy
    Central Coast, CALI
    Yeah, I knew they updated it when they updated TE a couple months or so ago. I haven't had time to update everything yet.
