hesistating off idle...cant figure it out!!!
Discussion in 'Civic and del Sol - EG and EK' started by 90htchbck, Jan 18, 2010.
  1. 90htchbck
    90htchbck New Member
    whittier
    my 92 civic si, single cam v-tec was running perfect then all of a sudden started hesitating/stuttering off idle...runs rough until about 3k then it smooths out. Does anyone have any idea what it might be?? just put new plugs about 2 weeks ago...i actually tried pulling out one of the plugs to see it if was fouling or anything and...ITS STUCK i can't pull it out...anyone have any idea how to get the plug out without damaging the head? :confused:
  2. joecivic
    joecivic save the single cams
    baltimore
    for getting the plug out i know you can get sockets that are made to remove stripped bolts they do make deep ones that will work with spark plugs,the only reason the plug would be STUCK if it was overtight or crossthreaded during install
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Were you drunk when you put the spark plugs in? lol j/k Cross threaded? Ouch Ouch Ouch.
    Was the car running fine after the spark plug change and then stuff started happening? Check Cap/Rotor, IACV, Old Plug Wires? Stuff like that might help.
