hey look at me!!!!!
Discussion in 'HYBRID -> EG-EK / DC' started by honda801, Nov 25, 2008.
  1. honda801
    honda801 New Member
    SLC
    Ok im not the smartest idiot on the planet but heres my question, I put a swap in my car and started it everything seems fine until i try to drive it then it boggs out. when I first finished i had it on stands and went through the gears (just to check the new clutch) and everything seems fine, of course its a little off needing a tune but why is it that when I put it on the ground it doesnt go? Is this still tuning or what am I missing? By the way it will be getting tuned, just curious if any one else has had similar experiance...
  2. doeboy208
    doeboy208 New Member
    i may be wrong but you may want to tune and chip your ecu.
    1 person likes this.
  3. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    what swap into which car may be helpful for us to know.
    are you getting ay CEL's would help also.
    that being said, as a complete guess I would say to clean/check your IACV
  4. honda801
    honda801 New Member
    SLC
    2000 honda si :
    gsr block with si head. it also has hondata, i know it needs a tune, but my question is basicly why does it seem to be running fine on stands but the second it touches pavement, nothing? i see these videos of people just throwing the motors in and taking their car for a cruise. Oh yeah and thanks for the reply guys...
  5. 801CRX
    801CRX Got Rice?
    UTAH
    Clutch slippage?
    Valve lash?
    It sounds to me like once it has to apply real force(I use real force, because on stands there is no resistance on its rotation) then it starts to bog.
    But thats just my 2cents!
  6. honda801
    honda801 New Member
    SLC
    what do you mean by valve lash, and what part of utah you from? I need to find a reliable hondata tuner around slc area, know anybody?
  7. lswhitecivic
    lswhitecivic Senior Member
    DFW, TX
    Do you mean it runs fine until you like hit the gas pedal? Like if you just start it while it is parked it runs fine until you actually try go? Did you just replace the timing belt? I had a car that did almost the same thing, started and ran fine at idle, but as soon as you applied gas it would bog.
    Turned out that one of the cam gears, I can't remember which one at the moment, was off by one tooth. Fixed that and it ran like a champ.
  8. honda801
    honda801 New Member
    SLC
    if its in nuetral it idles fine revs ok even on stands iput it in gear let out the clutch and everything seems fine. as soon as i took it off the stands and put in gear it leat out the clutch, i would say around 1500--2000 rpm's it just boggs.
  9. lswhitecivic
    DFW, TX
    Did you put on a new timing belt? Sounds real similar to the issue that I had.
  10. honda801
    honda801 New Member
    SLC
    yup!@!!!^$@#
    I'm going to check it out tomorrow!!
  11. austin20110
    austin20110 New Member
    Northern Va
    do you have torrettes or something?
  12. ghsbaseball91
    ghsbaseball91 New Member
    Catawba, Virginia
    hahahahaha nice pic austin
  13. 94H_Ex
    94H_Ex Under employed
    Florida
    sounds like timing. Runs fine at an idle but bogs on a load. Check sparks, timing in your belt and on your dizzy. Make sure your fuel pressure is right. does your Si head have vtec. Make sure your ecu isnt engaging vtec too early. That can cause possible bogging. Really no one can answer this question for you with the small amount of info you have given us. Your going to have to pull out a book and check everything making sure your engine is right.
  14. honda801
    honda801 New Member
    SLC
    im going to check all of these things today and i will get back.and yes its vtec. Im going to try and make a short video just to show you guys, but first i have to go stuff my face..
  15. 94H_Ex
    Florida
    hmm... still waiting on that video... either he never got around to it and fixed the problem. or... he said f' it and is still driving it to this day like it was...
  16. honda801
    honda801 New Member
    SLC
    sorry guys decided to send my s200 into hondata and have it updated to 300. Then i have the tuner of the town coming to fix it..
