Those fucking dudes at the tire shop... WTF
The bastards put only 35 lbs or less in each tire,
and I specifically asked them to put 48ish...
I mean how fucken hard is that!
Hate to bring up a post from earlier in the thread, but 35psi is what the manufacturer recomments...48 psi is WAY too high. Running THAT much pressure is going to cause the tire to swell up in the middle, and not let the whole contact patch touch the ground, causing the tires to wear faster in the center AND giving you less traction. Also, depending on what the 'MAX' pressure on the tire is, you run the risk of the tire blowing out.
Pressurize your tires by what the vehicle manufacturer recommends on the sticker on the driver's side doorjamb, NOT the 'MAX PRESSURE' on the side of the tire.
If you asked for 48 psi in your tires, you are a fucking idiot. Period.
well damn my b. at the time i hadn't done much research on it... but even just at 35 i was getting alot of outer edge wear... i just knew i needed a lil more pressure.
but you are def correct on that... my two front tires went to shit not long after. i learned my lesson lol the two on the rear are still goin hahaa
