hey noob question
Discussion in 'Prelude' started by splashofpaint, Feb 2, 2010.
  1. splashofpaint
    splashofpaint New Member
    canada
    hey pplz . here's my delemma..i just bought a 93 prelude (first honda) for a project car that has a f22 blown in it . i'm planning on putting in a h22 replacement .. i'm still reading post after post to find out what i'm getting myself into . my first ? is will my wiring stock wiring harness and ecu work for the h22 besides the vtec needing to be rewired , and will it bolt to the f22 tranny and engine mounts.. if anyone has come across a good guide on how to help me with this swap it would be greatly apreciated ...and yes i'm still readin posts not looking for someone to do it for me just some help
  2. DESPAIN
    flower mound TX
    EVERYTHING WILL LINE UP JUST FINE. YOU WILL NEED DIFF. AXLES AND AN ECU. ITS NOT A HARD SWap because the preludes where made for f/h engines.
  3. splashofpaint
    canada
    ok but if i can use my tranny y do i need new axles
  4. BrutalB83
    Rochester Hills, MI
    If you're keeping the Accord's transmission then you shouldn't. You just need the correct ECU...
