Hf Monster...
Discussion in 'HYBRID -> EG-EK / DC' started by flipend47, Feb 12, 2003.
  1. flipend47
    flipend47 Member
    hunts-vegas AL
    i had planned on putting an ls engine and tranny in a 91 crx hf and running turbo - the classic ls turbo setup. then i read the "creating an HF all-motor monster" article and was wondering if i could swap the heads, use some other si parts, and run the ls tranny for the turbo. good idea - bad idea? how much would that benefit compared to just running ls turbo? is it worth taking the long way areound?
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    personally i would save my cash and just get the LS motor.... for the 500 bucks that that swap will cost, that is half the cost of an LS motor and tranny...
    good luck man...
  3. koi_killa
    koi_killa Junior Member
    Since you didnt secify, i am gonna assume you are going to be using the ls block. Swapping out the LS head for a v-tech one is a fairly simple and streight forward plan. Its also a good idea in that you gain low end torque and high end power. Remember, all b series head, blocks, and trannies are interchangable with slight modifiacation. The article on the HF dealt with the single overhead cam non-vtech eight valve d series engine. Going from a d block to a b series head is impossible, it would just not line up properly, atleast as far as i know. I hope this helps
    Zee
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    he was referring to our "building an HF all motor monster" article by chet, which uses stricltly d series parts
  5. koi_killa
    Yeah i kinda figured that, but when he said that he would use the ls tranny, that threw me of into thinking he wanted to use the ls block with a d series vtech head.
    I dunno, maybe it was just me. hehe
