Hf To Si
Discussion in 'HYBRID -> EG-EK / DC' started by chad123, Apr 1, 2003.
  1. chad123
    chad123 Member
    OK i have 1988 honda crx hf..I found a 89 crx si head and ecu for cheap and i was wondering if i swaped my hf head and ecu with si head and ecu will i get any more horse power out of my car???
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    definitely. try to find the intake manifold as well. you will DEFINITELY notice a gain. your hf has an 8 valve head and is fueled for better gas economy. the si head is a 16 valve and will make a difference.
  3. whatdahieu
    whatdahieu Senior Member
    you would also have to switch from dual to multi point fuel injection
  4. biglee414
    biglee414 Senior Member
    no you dont have to convert to multi point fuel injection, an hf is already multi point, a dx is dual point fi
  5. D See 2
    Baltimore, MD
    werd
  6. chad123
    chad123 Member
    SO if i switch to an SI head and ECU im gonna get more power correct??..
  7. whatdahieu
    true story, i don't know what i was thinking :eek:
  8. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    Yeah, u will get quite a bit more of a boost in speed. Use the si manifold tho.
  9. chad123
    chad123 Member
    do yo uknow about how much more horse power i could get out of switching to si head ,ecu,manifold??
  10. Mech
    Mech Banned
    D15B6 (hf, your motor)
    Displacement (cc): 1493
    Power (bhp@rpm): 62@4500
    Torque (ft/lbs@rpm): 83@3000
    Compression Ratio: 9.1:1
    Bore (mm): 75
    Stroke (mm): 84.5
    Cam Design: sohc
    VTEC?: no
    OBD: 0
    Year(s) Produced: 1988-1989
    In the following car(s): Honda Civic HF / CRX HF
    With manifold, ecu, and head..... vwalaaa!!:
    D16A6 (si.... your upgrade)
    Displacement (cc): 1590
    Power (bhp@rpm): 108@6000
    Torque (ft/lbs@rpm): 100@5000
    Bore (mm): 75
    Stroke (mm): 90
    Cam Design: sohc
    VTEC?: no
    OBD: 0
    Year(s) Produced: 1988-1991
    In the following car(s): Honda Civic Si/ CRX Si
    All in all.... Very worth it. :spin:
  11. chad123
    chad123 Member
    WOW thats a nice gain!!!! and i can use my hf TRANSMISSION CORRECT??
  12. Mech
    Mech Banned
    yeah, but I'm not sure if the si has shorter gears or not. Look into getting the si tranny if it has shorter gears. But yeah, it's a very nice gain.
  13. chad123
    chad123 Member
    HF is alot lighter than the si soo thats gonna be a PLUS when i swap correct??
  14. Mech
    Mech Banned
    The Si tranny is a little different but I don't know if it's really worth spending your money. I think the HF is lighter because of the motor size mainly, and maybe a couple of interior things. Once you add all this stuff it should be about equall to the DX. The Si has the sunroof and power everything so it will wieght more.
  15. chad123
    chad123 Member
    so the HF transmission will work fine right??
  16. Jeef
    Jeef NO MA'AM Moderator VIP
    Yes but you will be slower with it.
  17. chad123
    chad123 Member
    where is my ECU located in my 88 honda crx HF
  18. crxswap
    crxswap Junior Member
    your ECU is under the carpet on the right hand side under the dash
  19. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    your numbers are not going to be the same as the d16a6, you don't have the same displacement.
  20. farmer_jason
    farmer_jason Senior Member
    florida
    your displacement will stay the same which means less torque then the d16a6
