Hf To Zc Wiring And Help With Questions.
Okay I have a 90' HF CRX. I just bought a motor from Hmotorsonline stuffed it in as I thought it was the right wiring and it wasn't. Now for some reason my car doesn't have fire to the plugs or anything. Question #1 Is the HF the EXACT same to wire up as the CRX Si? #2 What can I check besides the wiring I know I have the right distributor and the right ECU PM6 and the distributor from the CRX Si. Just some SERIOUS help within the next couple of days. My car is down and honestly I can't afford it to be that way for any longer what can I do? Oh and #3 Some sort of wiring diagram that I can print out. Thanks Fellas I know that you can help!
