Is the frame liter or its components?
1990 crx SI weighs in at about 2,175 pounds
the HFcomes in at about 1,950 pounds
the big difference in weight seems to me to be in the motor and the sun roof.
Example the HF motor weighs less than the SI motor so if you pull the stock motor ant drop in a b16 the weight not that much different because your changing out the motor(the main reason for weight difference)
Drop the sun roof and the advantage of an HF swap should not be that different.
Also what is the weight difference of the rear drum brakes compared to the rear disk. I would think the drums would be heavier.
I gues the only way to know is to weigh the dam car after the swap. I already broke my bathroom scale.<<<<<<<<<<<<<<just a joke
