p06 will not run a D16z6 VTEC motor atleast the vtec side of things. You will need the famous p28 ecu for the swap, can be found in a 92-95 Ex mainly.... If you plan on using your old harness I would advice not to, and get the harness for that motor as the new harness has a few extra plugs you will need. But there are ways around it... in the hybrid section
