High 11 Crx???
Discussion in 'HYBRID -> ED-EF / DA' started by punkkidd82, Jul 16, 2008.
  1. punkkidd82
    punkkidd82 New Member
    Im getting a b18c motor in 3 months and would like to know what I would have to do to the motor to get into the 11 seconds.
    Thank you,
  2. dacheat
    dacheat ..is grounded.
    strongbadia
  3. efhondakid
    Akron-Canton, Ohio
    Yeah its going to take a serious build to go that fast.
  4. punkkidd82
    anyone have good link for build for this.
  5. dacheat
    strongbadia
    i told ya, search for threads started by JustinSane, and start reading. he talks about his build quite a bit, he's got 4-5 threads, one of which i linked up.
    :shrug:
  6. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    honestly alot of money , for a street car , if you want 11s boost is your best friend , at minuum a turbo set up , some kind of managment system, a really good tunner . and learning to drive an 11 second fwd car . reasearch alot on this
  7. BrokenRex
    BrokenRex New Member
    he speaks the truth. well half of it... the other half is living with a fwd capable of 11's.
    maybe you'll have a clutch that requires both feet to depress. maybe you'll have a gutted interior with no ac or stereo. or maybe you'll have both. having a second car as your daily driver will almost completely negate this truth. i say almost, because there's going to be a point in time when you wish it would start on it's first crank. or when it overheats in stop+go. or when you pass out from the heat of the summer. or when you miss a gear and ventilate your block with a rod.
    unless you're 16, then forget i even said anything.
  8. SlushboxTeggy
    NJ to MA to CA
    Or a lot of nitrous, haha. But that wouldn't last long.
  9. phyregod
    phyregod !!YTINASNI
    Central Texas
    Boost the everloving shit out of it, slap it on slicks, and hold on.
  10. 97hatch
    97hatch ?
    Anderson IN
    i went 12.113 in my rex with
    b20 block $500
    gude racing ls head $750 used
    cable gsr tans $700
    quaife diff $800
    aem enginemanagement $1000
    wiseco 11:1 pistons $300
    eagle rods $300
    crower 402 cams $400
    tilton twin disk clutch $1000
    dss stage 3 axles $750
    bogart 13x9 wheels $400
    24.5x8x13 m/t slicks $300
    dsm 450 injectors $free from friend
    walbro fuel pump $150
    nitrous express direct port n2o kit $800 sprayed 200hp
    plumbing for fuel/ nitrous $200
    total $8500 or more invested
    plus the car and the cage and the seats and the belts
    countless other parts and gutted interior
    i would say that you can run 11s for about 4-10 k just depends on the quality of the build i spent to much on my car but i also bracket raced it every sat night for 2 years and only went thru spark plugs nitrous fuel and tires till i sold my motor to build a 800+ hp gsr motor and i dont have it completed due to funds
    i do have the complete dry sump system and a gt42 :D now just need the block sleeved and a massive fuel system to run methanol the rest is all little shit when you get to this point.
