High Beam Issue
Tein
So much with a little D
I got this issue with the driver side... The High Beam on the driver side dont work, low beam work fine on both sides but the high beam only works on the passenger side... The bulbs are new and I even switch them just to make sure that was not the bulb.
<p>I will try that when I get home... It has to b that, right? If it is how can I fix it?</p>
