high boost or high compresion
Discussion in 'Forced Induction' started by socalcivic, Sep 30, 2003.
  1. socalcivic
    socalcivic Junior Member
    I have a b18b and im wondering if theres a diffrence if I lower the compression and then boost it too 19 psi, or to raise compression and set boost at 6-8psi? Im gonna use a turbo from an evo8, with a fmic which one will make more hp, im planning to put a b16 head on in the future but first i wanna boost thanks
    alex
  2. NoJokE
    NoJokE Senior Member
    Its all about tuning and adding fuel/timing, etc. You can use 10:1 compression and boost a bar, just gotta get it tuned.
  3. jamesA
    :werd:
    lower compression will help because it won't ping, but that's only if you don't have the timing and air/fuel tuned right.
    you can boost high levels on high compression, it just takes a bit more patience, time and money.
  4. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    eventually the limit of boost vs. compression is determined by the octane gas you are running.
  5. NoJokE
  6. pissedoffsol
  7. socalcivic
    thank you thank you.... I think the turbo is a 20g, is that a good turbo for my application
    alex
  8. calvin
    calvin Senior Member
    NETHERLANDS
  9. liquid00meth
    Laconia, NH
    the 20g turbo is a nice small turbo, it will spool extremely fast, and give a nice boost in power. I would guesstimate it's good for like 225whp at max efficiency? I am unsure of that though.
  10. SolReaver
    SolReaver Senior Member
    :bash:
    20g supports wayyyyyyyyyyyyy more than 225 whp...225 whp is more like the 15g...20g is a kickass turbo and id rock it to 330-350 whp
    in size its roughly comparable to the garrett t3/t04e
  11. cws13
    cws13 Senior Member
    Athens,GA
  12. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    how do you guys rate turbos on how much power it can handle?
    there are some cars running high compression(about 10:1) and high boost(about 25psi) with regular 93 octane fuel. So i guess its all in tuning. I think those water injection systems would help in these kinds of situations.
  13. pissedoffsol
    I'm sorry, but I don't feel 10:1 is high at all. Its a medium level if you ask me.
    9:1 is low
    10:1 is average
    11:1 is moderately high
    12:1 is stupid high.
    Also, it is doubtful that you will ever see 25 psi on pump gas.... unless its a 14b tweaked to actualyl hit 25 psi...
    around 350 whp, regardless of the turbo, higher octane is needed, or a weak ass timing tune, wich eats power.
    IMO, water injection is over-rated so long as you have a proper intercooler.
