michaelgomez
i have a 91 crx si and did a 96 mini me swap along with 89 integra pistons and rods. i heard that the the head will raise compression about a point and that the pistons raise it another 3/4 point. then on top of that i had the block shaved .20 and bored .10. i figured my compression was going to be really high, so i bought a head gasket spacer kit from summit and put on about 1.25 mm. so now i figure my compression is going to be about 10.5-11 to 1. and i've heard alot about high compression and nitrous. and i was wondering if it would raise the compression so high that it will bend a rod or blow a piston, or if it will be ok?
thanks
meeko
thanks
meeko
