K K-V-NO Member Sep 12, 2003 #1 installed a high flow cat, check engine light came on, how reset and turn off check engine light
C CRXRookie Senior Member Sep 22, 2003 #2 The high-flow didn't come with the plugs for the O2 sensors? You need to get an O2 simulator.
K K2EP3 Junior Member Sep 29, 2003 #3 Originally posted by K-V-NO@Sep 12 2003, 01:39 PM installed a high flow cat, check engine light came on, how reset and turn off check engine light Click to expand... take off battery, and take off back up of ecu fuse for 10 sec will reset computer
C convertedstangbanger Senior Member Oct 20, 2003 #4 you dont need to pull fuses, just disconnect the battery for a few seconds.
