Originally posted by pissedoffsol@Dec 16 2004, 09:40 AM
define "burn out"
[post=433067]Quoted post[/post]
Originally posted by Bl6CRX@Dec 17 2004, 12:32 PM
cheap cat or you wouldn't happen to be bottoming it out would you?
[post=433693]Quoted post[/post]
Originally posted by b204dr@Dec 17 2004, 12:38 PM
the inside should not be comming out under normal circumstances- cheap cat shouldnt matter- unless its some thing home made- i ran an aftermarket no name that we welded flanges onto it its holding up just fine- as long as like said above running to hot or to rich-such as in turbo applications but being stock motored - and what not i could not see this in your case- im thinking you have some other issues with ur piping - have ur shit checked out maybe its clogged in the rear from blowing chunks prior causing heat build up - have it looked at or diy- thats my theory
[post=433697]Quoted post[/post]
