Higher Compression
Discussion in 'Engine Building' started by pills_PMD, Feb 21, 2003.
  1. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    if i raised my compression.. how should i compensate when adjusting my FPR.
    the car was running rich as hell, and i was planning on dropping the fuel pressure, but i'm thinking again since i raised the compression.
    do i need more/less fuel when having a higher compression?
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    If you're talking about higher compression, everything else aside, you shouldn't need any more or less fuel. Higher octane, of course. Think about it...you're compressing the same amount of "stuff" more, then igniting it....it's going to give you more of a bang. Shouldn't require any more or less fuel.
  3. pills_PMD
    New Albany, OH
    okay.. makes sense.. i was just wondering if it was not advisable to lean my car out a bit since i bumped the compression. thanks
  4. chet
    chet Senior Member
    st petersburg, florida
    it depends on how rich your car was running previously. its so hard to speculate, given the fact that i've never seen a dyno with your air/fuel ratio prior to the change in compression.
  5. chet
    chet Senior Member
    and play around with it a little. try leaning it out in the lower rpm's...and or giving the car fuel to see how it reacts...as i know i can feel a difference with a drop in as little as 5hp over a given range.
