Ok so I have a 1991 civic Ex 4 door that I put a 1998 integra B18a1 in. I used the Pr4 OBD0 ecu, and the OBD0 dist. to keep it simple. This motor was running great in the other car. But now here is the problem. When I take the car out and get on the freeway it smells really rich, and if i'm going 65 it's fine, but when i hit the gas to go faster or to pass the car will die. I turn the key off, and back on pop the clutch, and it starts back up. Runs fin till i get back on it then I do the same process. Does anyone know what it might be? I changed the O2, and messed with the distrib. timing. open to any suggestions.. thanks
