HKS racing wastegate spring
How do I know which hks spring I want? I jknow the colors are for different pressures but which one do I need? I have the blue one right now(not the light blue). Plan on running around 14-15 daily and 24 at the track.
This is what I found:
Racing W/G Spring 0.70 kg/cm2 Yellow $61.00
17245-015100 Racing W/G Spring 1.0 kg/cm2 Purple $70.00
17245-027100 Racing W/G Spring 1.3kg/cm2 Gray $52.00
17245-028100 Racing W/G Spring 1.6 kg/cm2 Brown
Thanks.
B20/vtec with sc61 turbo
its said that a boost controller is good for about double the wg spring... so if you want 24 at the track,. your going to want a 1-bar spring, and 14.7psi will be your minimum boost.
Purple it is
