HKS turbo timer& Alarm
Discussion in 'ECU's, Electronics, and Tuning' started by calvin, Feb 6, 2004.
  1. calvin
    calvin Senior Member
    NETHERLANDS
    Working of the turbo timer?
    What trigger the turbo timer to activate?
    because i have a wire on my alarm which must be switched off(gnd) when u want to turn the alarm on. Must be switch on(+12) when u want to start.
    I think something of relays but i need to know how the timer is trigger.
    Tnx in advance
    Calvin
  2. pissedoffsol
  3. calvin
    NETHERLANDS
    Tnx for your fast reply
  4. calvin
    NETHERLANDS
    Turbo & alarm
    I will use the brake input because that's 0 volt when brake engaged.
    Calvin
  5. calvin
    NETHERLANDS
    I have found away to do it with a relay.
    Look at the schematic.
    Alarm input must have 0 volt to ARM
    Alarm input must have 12 volt to Start the car
    Calvin
