I wanna swap a obd2 engine into my obd1 civic is there a obd1 to obd2 harness available for the ecus?
http://hondaswap.com/adverts/adclick.php?b...ww.boomslang.us yep or try hasport, or some of the other ads on this site.
What motor going into what car? I got away without needing a conversion harness for an obd2 b16 going into my obd1 civic using the obd2a GSR Harness.
I'm not more than 94% positive, but since the obd2 GSR harness breaks off at shock towers like the civic harness,it would be plug n play, except you will need an obd1 Ecu. .. [edit] After re-reading your first post, i guess you weren't asking about the engine harness anyways. If you go Type R, and want to use the Type R ecu, you will need to use an obd1 to obd2 conversion harness. If you go GSR, just get an obd1 GSR ecu. Sorry I'm sleeping
i have an 01 JDM ITR engine in my 93 sol running off an OBD-1 ECU no OBD conversion harnesses required
