homemade ITB
Discussion in 'Engine Building' started by ihatemyprelude, Feb 22, 2010.
  1. ihatemyprelude
    ihatemyprelude New Member
    Ocala, FL
    Just ran across this one night looking at diy stuff. This guy used tb's off a 600rr..
    DIY itb serie d - MONTREALRACING
    This guy used some gsxr tb's look at how he made the TPS work..
    HM-ITB
    This is a nice set up for the money ITB and head work makes for a fun honda.
  2. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    A guy I new was going to use them off a an R1, about three years ago...
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    You can use the stock TPS on the bikes as Crome, and maybe others, support different ranges.
  4. TurboMirage
    AFAIK all butterflies have a 1/4 throttle movement so i dont see why grafting a honda TPS onto any other throttlebody would be an issue.
  5. K2e2vin
    Raleigh, NC
    I'm sure you didn't get what I was saying.
    If you had GSXR throttle bodies, using Crome or other programs allow you to use the Suzuki TPS. This means less work; no need to fabricate a TPS mount.
    There is no issue, it's just a matter of doing something more easily/keeping things simple.
  6. ihatemyprelude
    Ocala, FL
    Nice thats good to know about tuning progs reading the gsxr tps. Will the 900rr tps read on chrome or hondata?
  7. newb
    newb phresh VIP
    Backwoods Northwest
    Ive got a set of the GSXR 750 TB's grafted to a B16 manifold in my garage now. Actually tryin to sell em lol. I never did get a chance to run em.
  8. Magana559
    Magana559 The Warden
    fresno Ca
    Man I would love to do this!
  9. Magana559
    fresno Ca
    PM'ed
  10. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    The problem with ITB's using hoseclamps like that is that the air doesn't have a smooth pathway to flow into the head - all the edges in the runners cause turbulence. If you're gonna do homemade ITB's, do it the right way and weld the runners and smooth/port them.
    HMT is such a ghetto, halfass hackjob site.
  11. K2e2vin
    Raleigh, NC
    Honda bike TPS readily work with Honda ECUs(same voltage range).
    If your runners are straight and ends cut to fit the clamps, they will work perfectly fine and be smooth, as seen in stock applications. Problem is, people use clamps as adapters. This makes transition even worse when the runners are bent like the OE runners that are cut to "fit" ITBs.
    Also, an alternative to welding and clamps is a flange/bolt system like how AE101 ITBs are connected.
  12. newb
    newb phresh VIP
    Backwoods Northwest
    Or you can grind the lips down in the runners to make the transition smooth.
  13. SlushboxTeggy
    NJ to MA to CA
    Always wanted a set, but on a stock Integra it would be rather pointless.
  14. GlassHeadlights
    Calgary, AB
    I am inspired! Make it on the cheap and rock it for the summer. :)
  15. JacobA
    JacobA New Member
    I was gonna make ITB's for my car before idecided to go turbo. If you want to go ITB you gotta red up alot on it. I still have my throttle bodies from when i was gonna build. there off a honda 929 cbr so the TPS works. if any one is interested and wants to know more PM me here is a link to another ITB build that you all may be interested in.
    HM-ITB
  16. TurboMirage
    works for most though. not everyone can afford their own tools or to have someone else fab for them ;)
  17. kelsodeez
    kelsodeez New Member
    bay area, CA
    anyone have experience/opinions on jenevy itb's?
