Honda accord 94 DX d4 blinking :(
Discussion in 'Accord' started by susi436, Aug 13, 2012.
  1. susi436
    susi436 New Member
    I put the plug to get the code. I got code 7 which i believe is the throttle position sensor, I changed it but after a day the blinking started again. My abs gave me a code 14 one long 4 shorts. Can anyone please help me. I have changed my solenoid sensor both.
  2. susi436
    susi436 New Member
    my engine light doesn't flashes just my d4 and abs, thanks
  3. susi436
    susi436 New Member
    honda accord 1994 dx d4 flashing please help :( - YouTube
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    thats going to be a transmission code, something is up with the trans or one of the trans sensors. google around for a bit about trans codes im not real sure on what the codes are, ive never had to deal with many automatics.
  5. Weezle1
    Weezle1 New Member
    I'm a noob on here but I have a codes list of D4 blinks. Yours is blinking 7 times so the symptoms could be:
    - Fails to shift (between 1st<->4th, 2nd<->4th or 2nd<->3rd gears only).
    - Fails to shift (stuck in 4th gear).
    Now the probable causes could be:
    - Disconnected shift control solenoid valve A connector
    - Short or open in shift control solenoid valve A wire
    - Faulty shift control solenoid valve A
    I had a similar code but with 8 blinks which is valve B. It was weird though because I just bought a new ECU and the car has worked fine since.
