Honda City B16A Swap
Discussion in 'HYBRID -> GD' started by jignesh, Jun 3, 2008.
Thread Status:
Not open for further replies.
  1. jignesh
    jignesh New Member
    Mumbai,India
  2. phunky.buddha
    Dallas / Fort Worth, TX
    For starters, you should have created a new thread for this!
    Welcome to HondaSwap!
    The engine swap looks pretty cool, but that doesn't look like any GD in the US, and it doesn't look like the Honda City that I've seen in Taiwan and Thailand. Does India have a different body style?
    What kind of turbo setup do you have? The dyno chart looks like it would be from a non-turbo car.
  3. jignesh
    jignesh New Member
    Mumbai,India
    Hi,
    This is a Honda City Type Z which was sold in India, Thailand & Malaysia which was sold in 3 variants in India a 1.3l. 1.5l and 1.5l Vtec. Have spent a bomb on doing up my car and actually logged in to discuss some issues when I happened to see this thread.
    I do not know what a Honda GD is as I have never seen one. The car is running a stock block and turbo was set at 7 psi. Vtec was not working when the dyno run was done and car was also not fine tuned. AM giving below a complete list of the mods done in my car.
    1> PORTED/POLISHED HEAD WITH STOCK COMPRESSION.
    2> COMP CAMS MID DURATION STREET CAM
    3> FIDANZA ADJUSTABLE CAM GEARS 4> FERREA DOUBLE VALVE SPRINGS
    5> FERREA ALUMINIUM RETAINERS
    6> FERREA STAINLESS STEEL VALVES. HIGH COMP CUT
    7> MELLING TIMING BELT
    8> HONDA OEM BEARING KIT
    9> HONDA OEM GASKET KIT
    10> COMETIC MLS HEADGASKET
    11> ARP RACING HEAD BOLTS
    12> COMPETION CLUTCHES (CC)- STAGE 2 CARBON KEVLAR CLUTCH SET
    13> PHANTOM GRIP LSD
    14> EDELBROCK VICTOR X RACING INTAKE MANIFOLD
    15> WALBRO HIGH PRESSURE FUEL PUMP
    16> AEM FUEL PRESSURE REGULATOR
    17> GARRETT GT28R BALL BEARING TURBO
    18> GARRETT INTERCOOLER
    19> TURBO SMART 38MM EXTERNAL WASTE GATE
    20> BOOST MASTER BLOW OFF VALVE
    21>
    Blox Racing Log Type Cast Iron Turbo Manifold with custom piping and End Can
    22> CUSTOM STAINLESS STEEL TURBO PLUMBING
    23> NOLOGY PLUG WIRES & POWER CORE IGNITION CORE
    24> WILWOOD 4 PISTON BRAKE SET FRONT
    25> REAR DRUMS CONVERTED TO DISCS
    26> COILOVER SUSPENSION
    27> FRONT & REAR STRUT BRACE
    28> YOKOHOMA AVS SPORT 205/50/15 TYRES ON LENSO
    29> RACE DYNAMICS STAND ALONE ECU
    30> HONDA TYPE R INSTRUMENT CONSOLE
    Can I request you to change the title to Honda City instead of GD please.
    Am sorry about the formatting as I have copy pasted from another forum.
    Regards,
    Jignesh
  4. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    Nice car, and beautiful pictures! Welcome to Hondaswap! :thumbsup:
  5. jignesh
    jignesh New Member
    Mumbai,India
    Need Help
    Hi guys,
    Wanted some info on what should be the ideal Oil Temperature in my B16A2 Turbo Charged car be. It currently goes to approx 210 F within 10 mins of switching on the engine and driving under 5000 Rpm. With slightly spirited driving it goes to about 230F.
    Is that normal as I do observe that the engine is consuming oil approx .5 litres in 15 days. Was advised to install a Oil cooler.
    Would love your inputs and advice on the same.
    Thanks in advance.
    Jignesh
  6. Accrdkid
    Accrdkid 5 lugged.
    NH
    To my knowledge that Honda City is based on the Civic and Integra platform, and if I'm not mistaken it also has a down graded commercial version as well.
    Some of the styling cues were used in the Acura EL version of the Civic sold in Canada as well.
    Thats a nice car though too bad the US market never got a hold of that model.
    There are so many one off models I have seen in person that I wish Honda would have made stateside, one of my favorites is the Honda Rafaga which is almost a smaller version of the Acura RL from 1996-2001.
    1 person likes this.
  7. phunky.buddha
    I'm pretty sure that the City is its own platform, and significantly smaller than the Civic. The City and Fit share the same chassis in the current generation.
  8. spoondb2
    spoondb2 New Member
    the city shares the platforms with the acura el in canada and the civic from my understanding
  9. George777
    George777 ^^ Likes Bewbies
    With your mom
    This thread is 4 months old. I don't think the OP really cares anymore, especially since he hasn't even logged on in two months.
  10. YBLEGAL
    NW Indiana
    I think it's worth compiling info if it's not anywhere else on the web. At least it's here.
  11. Riseagain97
    Riseagain97 New Member
    Normal,Illinois, United States
    Some corrections about the Honda city.. It was based off the 1st gen Domani platform which was based on the EG civics how ever not very many interchangable parts between the EG and the 1st gen domani maybe front end and probably engine mabey suspension but other than that i dont know the body lines arent really the same... The Acura 1.6 EL was the 2nd Gen Domani wich was a Ek body civic with a diff front end how ever Doors out side taillights windows and frame was all a civic. and all parts were interchangeable via bolt on no body work needed. a few people in the states convert there 4 door civics to domanis and ive converted my front end to domani
    This is the second gen domani AKA the acura 1.6 EL
    And the honda City
    But as for the honda city and the swap i know my freind is from india and he said there are a few people that do the swap over there since its based off the EG i would imagine it woulnt be any different than putting a b16 in an EG civic
  12. phunky.buddha
    Huh? Maybe that one... but not the City that the USDM Fit is based on.
  13. Riseagain97
    ya that ones pretty much a fit sedan the new one but i think this dude has an older one
  14. jignesh
    jignesh New Member
    Mumbai,India
    Hi Guys,
    Am sorry I forgot to update the thread. My problem is sorted out for now. I have overhauled the engine and installed forged low compression pistons, rods & crank. The car now makes about 230WHP @ 12psi tuned for daily drive on 87 Octane.
    Have a new question can I install the radiator belonging to a Automatic transmission Honda City which is exactly the same size but has a oil cooling line to cool the engine oil and would that help in reducing Oil Temperatures.
    Currently the oil temp is between 180-190 *F and goes upto a max of 210*F under boost.
    Thanks in advance.
    Jignesh
  15. bcde323
    bcde323 Banned
    puma
    :diespam:
  16. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if i was a mod a would ban the hell out of you
  17. phunky.buddha
Thread Status:
