honda civic 1995 distributor timing
Discussion in 'Civic and del Sol - EG and EK' started by HugoX, Apr 18, 2010.
  1. HugoX
    HugoX New Member
    San Pablo Ca
    hey i went to get my smog done. it passed barely. im timing was advance. i haven't adjusted my distributor. i heard that i have to jump a connection while im adjusting. what is the connector? heres the pics of the connection near my ecu and the timing marks near the the pulley
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    Alright... #1 is for u to put a paper clip into and get the cel codes from your ecu via ya check engine light if there are any... only way I have ever herd to advance or un advance ya Dizzy is to un do the 3 bolts and move it around a bit... I don't recommend screwing with it alot... about the only deal i got for u
  3. HugoX
    HugoX New Member
    San Pablo Ca
    thanx dude. but i know how to adjust the timing. its just recently i heard of jumping a circuit to adjust the timing.
  4. EP3Hatch1987
    EP3Hatch1987 Meeeeooowww!!!!!
    No need 2 do that.. Juss unbolt the three bolts and make sure the top bolt is in the middle.. And make sure your at TDC
  5. SiR Master
    SiR Master New Member
    Why are you trying to play with your ECU ? Just set your timing properly and leave the ECU alone.
