honda civic 1998 ex gsr swap
4drteg54321
I just finish swapping my obd1 gsr motor in my honda civic. The car will barley want to start and idle rough. I got the jumper harness and put the obd1 p72 ecu. I also cant gas it, if i try it just act like it gonna die. Any advice would help. This motor came from my running 4drteg. Is it my TPS or Map sensor?
I try it again today and it only ran good once. I could actually push the gas pedal. But then when i turned off and on. The problem came back again. What can it be?
whats up did you ever get your swap running properly not sure how much help I can give but I do have a college degree and ase so if your still in need of help feel free to hit me up.
