PA Honda garage sale
Discussion in 'Parts: For Sale/Trade/Wanted' started by kchief89, Jul 8, 2009.
  1. kchief89
    kchief89 New Member
    Coopersburg, PA
    B, D and H series parts - B series into an EF/ED shift linkage, Brand new Luk clutch
    (3) RB20DET Side mount intercooler $20 Ea
    H22a Alternator $30
    h22a P/S pump $60
    H22a engine harness (JDM uncut)
    88-91 CIVIC
    pr3 chip (knock/speed limit disabled/stock fuel/ignition maps) $20
    D-mounts w/Energy suspension poly inserts $30
    89 Luk clutch set (brand new) $75
    B series shift linkage (B into EF/ED chassis) $60
    F/R factory sway bars (Front = Civic sedan R = Integra) $30 for both
    92-95 Civic
    oem muffler for hatchback $20
    oem muffler for del Sol (new) $30
    D-series A/C compressor $50
    (2) D series P/S pump $50 ea
    del Sol driver side headlight $30
    d15b7 distributor $30
    oem mounts for B series into hatch (JDM B16a) $50
    (2) 4 wire O2 sensor $10 ea
    upper radiator hose (new) $10
    D16z6 H20 Pump (new) $30
    Si gauge cluster (7200 rpm tach) $50
    d16y8 camshaft $10
  2. wizzkidd7188
    wizzkidd7188 New Member
    Do you dtill have the A/C compressor and is it any good?
  3. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    do you have the h22 5-speed trans rh side ear bracket and pic for it??
  4. superlude1996
    superlude1996 New Member
    Anderson, SC
    do you still have the 4wire o2 sensor?
