Honda Ignition Coils
34diesel34
Import Tuner
I need to know if the ignition coil out off a TD42U distributor will work in a TD44U distributor. The TD42U distributor comes on a sohc d16z6 engine, and the TD44U is what my B16a uses. The ignition coil on my B16a didn't pass the resitance test and I was wondering if the coil from the TD42U is the same before I go spending money on something I have laying around.
I checked with autozone for the part numbers, and they said the ignition coil for the TD44U distributor is the same part number for the TD42U. I'm going to try it and see if it works.
