HONDA old cars, converter for distributorless.
Discussion in 'Vendor Classifieds' started by yohsuke, Jul 21, 2009.
  1. yohsuke
    yohsuke New Member
    Forsale:
    For HONDA old cars, converter for distributor less.
    Do direct fire with the coil on spark.
    From Taiwan.
    Watch the UTube video
    B16A DSD-2
    YouTube - B16A + DSD-2 kit, 1st generation, simple installation 3 minutes
    YouTube - B16A DSD 2 Kit(1G) browse view
    YouTube - B16A DSD-2 closer view of the kit components
    H22A DSD-2
    YouTube - HONDA DOHC H22A Engine with DSD-2 (browse view)
    YouTube - H22A engine cranking with 2nd genaration DSD-2 (Cranking)
    Installation accessories for some SOHC engines models also available.
    Contact me with email simon@car-hacker.com
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    can you explain how this works???
    also are there any downsides to using this system?
    any loss of power or and CEL's coming on??
    how much
  3. DESPAIN
    flower mound TX
    yes tell me about the h22 dsd
  4. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    i like the kit,tell how its installed on a h22 vtec???
  5. klyph
    klyph Dismember VIP
    North Pole, AK
    I like the idea, but I'll bet B wants you to be a sponsor to sling your shit here.
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I've seen this on a couple of other forums; but noone can get their hands on them. What a tease :p
    Anyways, biggest concern was whether the unit is designed to fire inductive or cdi coils and if addresses the timing differences.
  7. Briansol
    Vendor approved.
  8. yohsuke
    yohsuke New Member
    mostly have positve response,especially the improvements below 4000 rpm.
    regarding your "downsides" concern,
    some claim that they cann't reach the top speed that they used to have.
    the top speed problem I thik should due to the exhaust pipe not big enough, for the DSD-2 help alot at burning.
    during the low rpm the same exhaust pipe can still work fine, but not enough during the high speed and high rpm.
    there won't be any CEL, I thnk no one can accept a modification part will arise a CEL light.
    It's USD550 shipped. Group buy or quantity ourchase can have discounts.
  9. yohsuke
    yohsuke New Member
    yes, I have my Accord H22A swaped.
    It suprise me very at the first time testing the DSD-2 to rev at high rpm as high as 8000rpm, though mine have no rev limit.
    It revs too fast to shift to 2nd gear.
    And, of course it's compare to the stock silicon cables, and a aging distributor. But who's H22A is not aged?
  10. yohsuke
    yohsuke New Member
    Is B for the Brian?
    I am really sorry for not taking care of the rules to be follow.
    The vendor access is solved now. It's my bad.
  11. yohsuke
    yohsuke New Member
    yes, I posted it on many sites. I got even banned at SuperHonda :ph34r:
    regarding the timing:
    there is only only slightly timing difference.
    the electronic timing delay is 4us, which is close to 1 degree at about 7000~8000 rpm. 4us = 4/1000000 second
    one shouldn'y mind about that difference. for one that really cares, one still can rotate the distributor to store back the timing.
    but phically, the burning speed makes you feel nothing about the 4us retard.
    regarding the inductive or cdi coils":
    every "coil" is inductive!!
    but each of the coil stick have it's own controller.
    so we don't care about the analog part control, this product simply do the "digital" signal process.
    and of course the coil stick is not my product or invention, it's modified from a standard oem coil
    stick
    DSD-2 is far different from the so called VSD which raised the supply voltage.
    higher voltage have high possibility to burn the coil.
  12. klyph
    klyph Dismember VIP
    North Pole, AK
    Have you got anything in the works for D-series? And are these only for OBD-1?
  13. INJEN78
    INJEN78 HS LEGEND
    OHIO
    very cool..id also like to know about the Dseries..
  14. yohsuke
    yohsuke New Member
    YES. D-series suported. Both OBD-I and OBD-II
    I will post the video later.
  15. yohsuke
    yohsuke New Member
    accord's SOHC engine also supported
  16. DESPAIN
    flower mound TX
    so why is this so much better?
  17. yohsuke
    yohsuke New Member
