Yeah I know- I just thought there was a reverse rotating VW transmission out there.
Originally posted by friz@Jan 19 2005, 06:47 PM
Guess it would have to be an f20 huh..
[post=448313]Quoted post[/post]
Originally posted by E_SolSi+Jan 18 2005, 07:59 PM-->Originally posted by friz@Jan 18 2005, 10:02 PM
Celerity@Jan 18 2005, 07:49 PM
It's very easy to adapt engines for RWD transmissions. The bell housing is approximately the same size as the Mazda RX-7 trans.
-> Steve
[post=447721]Quoted post[/post]
I really don't want to have to build a custom bell housing....Does any one make a conversion bellhousing for this setup?
[post=447724]Quoted post[/post]
this is where the small detail of the damn honda engines spinning in the opposite direction of all other engines ends up fucking you in the ass.... if you were able to get an adapter plate made up you would have 5(or 6) gears in reverse and 1 forward
[post=447751]Quoted post[/post]
Originally posted by Calesta@Jan 19 2005, 02:05 PM
Brain's been in "Honda-mode" too long.
[post=448072]Quoted post[/post]
Originally posted by BodyDroppedNikes+Jan 19 2005, 08:13 PM-->Calesta@Jan 19 2005, 02:05 PM
you should put your brain into "mini-trucker mode"
[post=448370]Quoted post[/post]
Originally posted by Celerity@Jan 20 2005, 12:45 PM
Another thing to consider about a small engined powered "Rat Rod".. With a V8 or V6 you'll still get great economy. It's got no weight to carry around !
When I was doing V8 swaps in Blazers, my trucks were getting or same (with big power increases) gas economy because the driver didn't need to flood the float bowls (Or push 45 psi out of the rail) to make the thing move.. Smaller engines do consume less fuel per revolution, but if it takes twice the revolution to make it move - Then where does that get you ?
-> Steve
[post=448759]Quoted post[/post]
Originally posted by Calesta+Jan 20 2005, 04:11 PM-->Originally posted by BodyDroppedNikes@Jan 19 2005, 08:13 PM
I've been doing that- but I just can't get "sparks" "bags" "notches" and "d00g excessive negative camber iz coo y0" to compute to anything useful in my head.
[post=448773]Quoted post[/post]
