HondaDelSol b15 rebuild
DelSlow89
93 Del Sol
I Have a 93 Honda Del Sol b15. I am either looking to upgrade to an imported b16 or b18c1. Or just rebuild the b15 with high performance internals. If any one has any advice as to which of these i should look into please reply. Thanks alot.
There is no such thing is a b15. I'm guess you mean a d15? Its it a d15b vtec? If not I'll say get a d16z6 if you are on the budget. If money is not a concern the get a b-series. But remember that you can build a fast sohc turbo motor for the cost of a b-series swap.
Kind of new to the whole honda thing sry. I'd like to get the b16 but what would i do to make the d15 faster.
That motor isn't really worth much for making power, IMO. However, I've heard stories of people doing it and being just fine, as well as failing miserably. Overall, I don't think you'll want to bother with it.
Build a turbo-D. Find an A6 bottom end, a Y8 head\intake, do a kit for 10psi, and you'll be rolling on B16s :)
a b16 with minor mods would light up a d16 vtec turbo, seen it a million times. Stock b16 with lightweight flywheel and header verse mostly stock d series turbo. Not to mention if you are thinking about going turbo go with a b series and it will make far more power on the same turbo setup as the d. You just have to add the price of a swap, i know this is pricey trust me. I think its worth it but plenty of others here will dissagree. Good luck.
i agree if you have a good d15b7 turbo it, like a bad mutha' til you blow it up.
then use the still good parts and build a mini-me turbo well and you'll be set.
