Hondas, turbo, and sleeves
Discussion in 'Engine Building' started by timEspeed, Dec 28, 2002.
  1. timEspeed
    timEspeed Senior Member
    Are there any Honda engines that don't have the "siameased sleeve" design? I.e. an engine ideal for boost? Resleeving can be damn expensive.
  2. pissedoffsol
    h22 97+
    but you gotta sleeve it to run forged pistsons.
    so your answer is no. lol
  3. timEspeed
    well aint that some shit...
    how well do them sleeve guards work? where can I find 'em?
  4. pissedoffsol
    its called a block guard.
    it goes in the water jacket sleeve.
  5. phunky.buddha
    Dallas / Fort Worth, TX
    The drop into the water jacket between the sleeve and the block
    They're typically made by Nuformz
    They cost about $100-150
    They rattle a lot
    They cause a lot of extra vibration in your sleeve
    :lol:
  6. nestle_2000
    nestle_2000 Junior Member
    Hey those are kinda cool...how much does resleeving cost though?
  7. phunky.buddha
    Typically $800-1200, depending on where you get it done, if you're looking for reinforced sleeves (like Golden Eagle's monster sleeve setup), if you're boring out your block, if you're raising your deck, etc...
  8. timEspeed
    ok they rattle alot, makes sense. Do they do the job though? What if one was to weld it in?
  9. pissedoffsol
    welding it is common. make sure the block is decked .0001 to clear off any extra shit on the top.
    theres much debate about them... good or bad...
  10. nestle_2000
    Damn re-sleeving is expensive! I guess if want crazy amounts of boost ya gotta do it. My mustang handles 18 pounds of boost without skipping a heartbeat. Mind you, I don't run down the highway or up the street with a consistent 18 pounds...lol. In the city I sometimes see 6 to 10 tops, that's about it.
    So do they slide it in halfway down and weld it in then? It still rattles at that point? Perhaps the cooling is affected since there's not as much water flowing through? It seems like a good idea...similar concept as a girdle for a domestic. Do they make girdles for imports?
  11. phunky.buddha
    If you weld it, it won't rattle.
    Cooling is affected since it blocks most of the coolant's path, but the holes in the guard are there to let the coolant through.
    Yes, they make girdles for imports... but I assume you're talking about crank girdles. The GSR engine has one it in already, and Z10 makes one to bolt up to other B blocks.
  12. nestle_2000
