Hondata 4 bar map sensor
Tein
So much with a little D
I am trying to find out if it is necessary or if I need to purchase a HONDATA 4 BAR MAP SENSOR...
Could someone tell me if I need this item?
On my d16y8 I have a Hondata S300, RC 750 injectors, Golden Eagle fuel rail, Aeromotive FPR, ss fuel lines, GT35R82 (Garrett), boost control etc. block and head has being build from ground up and a ZEX 75 shot...
MSD 6AL, MSD cables and MSD coil...
With this add on do I need the Bar Map Sensor?
PWM Boost ECU Components
obd1 oem sensor is a 2 bar. (1 bar is for atmosphere +/-2psi, which leaves you roughly 11 psi to go). if you plan to go over 11psi, you need either a 2.5, 3, or 4 bar. Most people run a 3-bar from GM.
I purchase a SpeedFactory 4 bar map sensor... Now I am waiting for Hondata to send me the Presocket P28 with boost capabilities and the next stop is the Dyno...
