hondata AND boost controller
Discussion in 'Forced Induction' started by integramic, Apr 9, 2004.
  1. integramic
    integramic Member
    I have a hondata 3b and a blitz scb i-d boost controller. Does the hondata elimate the boost controller? I'm building a wiring haress and need to know. Thanks.
  2. pissedoffsol
    no. hondata has 0 control over boost, and boost controllers have 0 control over fuel and igntion maps.
    however, they need to be speced togehter- IE, boost controller set to 15 lbs, hondata maps need to be extended to 15 lbs as well- if not 17 in case of slight over boost
    and why are you building a wire harnes... i don't kget it.
  3. integramic
    integramic Member
    But it does elimate a vafc, right??
  4. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    hondata does eliminate a vafc, yes. A boost controller just manipulates your wastegate.....
  5. integramic
    integramic Member
    I also ordered 1000cc precision injector. I have to run an injector resistor from an older civic, right? Thanks.
  6. pissedoffsol
    if they are peak/hold, yes
  7. turboB20hatch
    turboB20hatch Senior Member
    pacific nw
    danggggggggg those are some bigggggggggggggg injectors
