hondata and obd0
crizx
ok i got a ef civic with a chipped pr3 with hondata s200.. well i havent ever had to mess with in in a long time until i rescently switched over to a ls vtec from a b16...
well i find that hondata no longer supports these ecus... and i really aint got the money or the want to switch over to obd1... what can i do at this point??
i just want to lower my rev limiter and a few sensors.....
is there a way i can get away from the hondata and run a program that id be able to tune myself ??
ecu doesnt really need a tune just want to disable a few sensors..
and change the rev limiter and vtec engagement point....
I didn't think Hondata had suitable ECUs other than a stage2 (old ECU) to suit OBD0... ??? does the S200 suit?
if you're already converted to obd1, there's no need to even worry about obd0 ecus or programs.
you CAN tune hondata your self. you just need to buy the software to do it.
or, you can move to crome
oh, mis-read.
turbo edit is ok. i tuned a turbo zc with it... wasn't great, but its better than nothing i guess. it's an option
