hondata constant tuning???
Discussion in 'ECU's, Electronics, and Tuning' started by imprt92, Aug 23, 2004.
  1. imprt92
    imprt92 Member
    i was talking to a friend of mine and he said if you use hondata you have to tune it all the time. tune it for different temps outside and for elevation, that sort of thing another told me just have it set on a dyno and you are good to go! so which is it? if i use it will i need to tune it all the time??? thanks
  2. phunky.buddha
    Dallas / Fort Worth, TX
    No, you just run it on the dyno and forget it. It's the same with any other tuning method. If you want to tune it for different elevations or other conditions, you can. You can't with the stock ECU setup.
  3. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    wrong. USDM ECUs have a barometric pressure sensor to compensate for altitude and weather changes. Retuning the car for altitude is a fine tuning thing - unless you've tuned the car so close to the edge that sneezing at it will make it ping, there will be plenty of room for changes in atmospheric pressure without incident.
  4. imprt92
    imprt92 Member
    so are you saying that it will or wont need to be re tuned in summer and winter?
    i really want to learn about this before i buy it!
  5. radnulb
    Sinsinnaty, Ohio
    depends on how it is tuned. read what I wrote again.
