understand that both hondata and uberdata are pieces of software that allow you to analyze data, make adjustments, and burn chips.
neither are nothing more.
Neither needs a dyno to tune-- but you do need other tools to tune, such as a wideband o2 meter, and preferrably an EGT sensor, and most importantyl, and long, straight road with no traffic so that you can do some street tuning, and a partner to either drive, or to sit in the passenger seat and hold the laptop/start the readings, etc.
that said, going to a dyno is much easier, and can produce slightly better results IMO.
I condone street tuning first to get your map pretty good so you aren't wasting a lot of time that costs money on the dyno. then, go to the dyno to finish up your map for the fine tune.
Ease of use goes to hondata IMO. The interface is a little cleaner than uberdata. but either is very easy to learn how to use. i picked it up in a couple hours at the dyno.
better results- niether. Again, they are analytical software. YOU or your tuner control the results, based on knowing how to read a/f, ignition timing, etc, and knowing what to change it to.
extreem tuning/fine tuning, they are pretty equal. again, it comes down to the user, not the software.
I think you are seeing these systems as a thing that reads and makes changes on the fly and tunes you. Unfortunately, thats not the case at all.
here's some reading you should do, that don't necessarily pertain to hondas- but general electronic fuel injection tuning.
http://www.carcraft.com/techarticles/78118/
http://racingarticles.com/article_racing-62.html
http://www.diy-efi.org/gmecm/papers/tunetip.html
http://www.sdsefi.com/techdynojet.htm
http://www.sdsefi.com/techtheo.htm
http://www.sdsefi.com/techegt.htm
http://www.sdsefi.com/techcomb.htm
http://www.sdsefi.com/tech400.htm
http://www.sdsefi.com/meltdown.htm
http://members.aol.com/dvandrews/ems.htm
books:
http://www.themotorbookstore.com/high-perf...-injection.html
and if you can, take this class that ben strader holds at various shops around the country...
http://www.efi101.com/efi101.html
if all of that doesn't make perfect sense to you, hire a tuner.
