hondata
Discussion in 'ECU's, Electronics, and Tuning' started by 2 litre EG, Dec 18, 2002.
  1. 2 litre EG
    2 litre EG Senior Member
    so cali
    well in reality its pretty much the same... it was designed in order to replace stages 2/3/4. but it depends on what ECU your running... it will replace all ECUs except for automatic, PR3 or PW0... personally when i went to get my Hondata i went through Ericks racing here in sunny so cal, and had the guys who tuned his car [Enichiro @ Zero Factory] tune it for me...
    if you were to get the s200 with 3 step rev limiter, and that pretty much equals the stage 3, but i do believe it has more tuning capabilities...
    i was in the same situation as you so i went to Ericks and asked him straight out what do you recommend, and he recommended the stage 2 for me but i wanted launch control so he upgraded thpackage for me.... hope that helps a lil bit
    :blink:
  2. 2 litre EG
    so cali
    need any more info check out
    Hondata S200
    read carefully and all the info should be there, if not then contact doug macmillan at hondata, he is the one who created hondata, and he can explain any other questions you may have
  3. richie_vei
    richie_vei Member
    thanks for the help im getting the engine tommorow
    :p B) :worthy:
  4. richie_vei
    richie_vei Member
    who's running a s200 chip then n is it any good
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i'm running a stage 2 w/ datalogging and it OWNZ you
  6. richie_vei
    richie_vei Member
    im gonna get s200 stage 3 think there about 400 dollars which i think is about 250 in pounds not to sure and thats a really good price though
