hondata ????
Discussion in 'Engine Building' started by 97CTR, Apr 2, 2004.
  1. 97CTR
    97CTR Senior Member
    My car is a 97 ex coupe, I am going to be running hondata on my ctr. I know that you cannot run hondata on obd2. I will be using rc 440 injectors. Can I use my pct ecu or do I need to get an obd1 ecu and use a harness jumper? As you can see I am a little confused, so my basic question is what do I need to do to use hondata on an obd2 car.
  2. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    hondata doesn't have a system for the PCT ECU. you'll have to use an OBDI ECU like a P28, P30, P61 from a 93 gsr, or a P72 from a 94/95 gsr. there are some other ones you can use too.
  3. HellBentHONDA
    HellBentHONDA Senior Member
    wa state
  4. pissedoffsol
    p28 is all you need. To save time and hassel, I'd just buy their obd2-plugged p28. that way you don't have to get a conversion harness either.
  5. E_SolSi
  6. 97CTR
    97CTR Senior Member
    sweet, thanks
  7. Teambypass
    Teambypass Senior Member
    I want to run hondata with my set up too, but I have a p72 obdII and a p73 obd2 modified to 9200 and I dont want to buy the p28. I will run p73 for now and see what i get out of 1/4. thanks for the info
