Hondata
Discussion in 'ECU's, Electronics, and Tuning' started by HondaMan_2002, Feb 27, 2003.
  1. HondaMan_2002
    HondaMan_2002 Member
    How does it exactly work?
    And what is the best system?
  2. NoJokE
    NoJokE Senior Member
    Hondata Check that out and it'll answer a lot of your questions
  3. HondaMan_2002
    So I would need an obd1 ECU to use a hondata system?
  4. NoJokE
    yea OBDII is harder to crack and they havent succeeded, so swapping in an OBD I is the only way to use a Hondata system
  5. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    I could be wrong, but didn't Hondata just announce compliance with OBD2 systems?
  6. NoJokE
    Really? I havent checked the site in a while, i've decided to get AEM EMS
  7. HondaMan_2002
    So what would be the best ECU to get if I am geting a B18C1 that is OBD2?
  8. dohcvtec_accord
    The left lane
    Yeah, I've got a GReddy Emanage system that's waiting to be installed.
    I swear someone posted something in the Anything Goes forum a few weeks ago about Hondata's new S200 system being able to be used with OBD2 ECU's. Or it's just over the horizon.
  9. NoJokE
    just checked the site, yeah it seems that they made OBDII plugs for OBDI ecus to plug into OBDII cars
  10. NoJokE
    P72, thats a GSR's OBDI ecu, that would be perfect
  11. HondaMan_2002
    So I would have to buy the OBD1 ECU and the Adapter to make it work with my new engine?
  12. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    yea... pretty much, but its worth it, im getting my s200 put in the lude in a couple weeks :)
  13. 2 litre EG
    2 litre EG Senior Member
    so cali
    are you going all motor? if so and you dont have money to get a hondata tuned then stick with an Ericks racing tuned ECU.... i do believe he is the number one ECU tuner right now, and he is also certified by Doug Macmillan [owner and creator of HONDATA] to tune hondata...
    it all depends on what you want, dont get the hondata just to say, "i have hondata..." make sure you get it cause you need it. and remember once you get the hondata get it tuned properly by someone experienced
  14. BlackJDMdeath
    Wichita, KS
    the dealer im getting it from is tuning it for me, believe me i need it lol... im running a p28 ecu on an h22a, lean much? yea. IMO hondata is also a good deal because of all the options for it and the things you get with it, like shift light and REAL vtec controller that changes the fuel maps with the crossover point.
  15. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    hondata does not automatically change your fuel/ignition maps when you adjust the VTEC crossover using the pushbutton, nor if you change it in romeditor. you have to adjust manually if you want to.
    i just spent like 4 hours playing around with romeditor and pocket programmer trying to get ready for tuesdays dyno appt.
  16. pissedoffsol
    what are you doing about the IAB's?
    you are loosing a shit load of power if you haven't:
    a- activated them via p13 or p72 that controls it
    b- removed it by swapping to an intake mani that doesn't have iab's
