hondatata info
Discussion in 'ECU's, Electronics, and Tuning' started by cxjon, Sep 28, 2002.
  1. cxjon
    cxjon Senior Member
    man+k+toe
    http://www.hondata.com
    Naturally Aspirated
    Stage 1 $213.75 Available for OBD-I ECUs in late 2002.
    Stage 2 $295.00 Full tunability over idle speed, injector size, fuel, ignition, VTEC point, fuel cut, and shift light rpm. Requires stage 4 or dealer to tune.
    Stage 3 $475.00 Two stage rev limiter for drag launch, full throttle shift, VTEC controller, Shift light LED all stage 2 features. Requires stage 4 or dealer to tune.
    Stage 4 $845.00 HondaLogger (real time datalogging software) and ROM Editor (fueling and ignition software) all stage 3 features.
    Forced Induction
    Stage 2b $545.00 Full tunability over idle speed, injector size, fuel, ignition, VTEC point, fuel cut, and shift light rpm mapped for up to 29 lb boost. Requires stage 4 or dealer to tune.
    Stage 3b $725.00 Two stage rev limiter for drag launch, full throttle shift, VTEC controller, and Shift light LED mapped for boost all stage 2b features. Requires stage 4 or dealer to tune.
    Stage 4b $1095.00 Datalogging and ROMeditor for custom fueling and ignition maps for boost all stage 3b features
    Installation charge to upgrade your ECU $50. (no cores)
    Upgrades
    Datalogging $200.00 Upgrade for stage 2 and 3. Allows user to record all input sensors in realtime for future playback.
    Boost $300.00 (stock MAP sensor) 11lb upgrade for stages 2, 3 and 4 ($250 if purchased with a system)
    MAP Sensor $90.00 (replacement MAP sensor) reads 28psi for stages 2, 3 and 4
    Accessories
    EEPROM chip $25.00 Reburnable chip for Hondata ROMs
    Injectors $380.48 Four high impedance RC 440cc injectors with clips to fit most Hondas
    Adapter Cable $200.00 Adapts an OBD-I ECU to work with an OBD-II vehicle
    Programmer $270.00 EPROM programmer and emulator for chip writing and fast tuning with Stage 4. Includes 12v wall adapter and in-car adapter.
    Gasket $57.00 Heatshield gasket kit for up to 30 degree lower intake temperatures and 3-9% more power.http://www.hondata.com
  2. cxjon
    cxjon Senior Member
    man+k+toe
    i m a fucktardâ„¢
  3. paragus
    paragus Senior Member
    yes u are. and dont forget about the s200 :D
  4. cxjon
    cxjon Senior Member
    man+k+toe
    it wont let you go back and edit it :(
  5. paragus
  6. wildbillhatchbac
    wildbillhatchbac the OG VIP
    really? you can't edit yoru own posts?? you should PM pissedoffsol y0
  7. cxjon
    cxjon Senior Member
    man+k+toe
    it will but wont let me change the eror on the hondatata in the topic. i feel like a dumb shit.... i cought it after i hit add reply
  8. slohnda
    slohnda Senior Member
    Sierra Vista, AZ
    wow, thats embarassing ;)
  9. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
  10. paragus
    yea i dont think your suppose to be able to change the topic. I think your just suppose to be able to change your post(s). I believe only admins can change/edit topics.
  11. cxjon
    cxjon Senior Member
    man+k+toe
    at the old forums you can change the topic
  12. paragus
    really?? damn i didnt know that, but then i never tried to do that.
  13. cxjon
    cxjon Senior Member
    man+k+toe
    i fuck shit up all the time so i m sure about it :D
  14. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    lol i didnt even notice it until you guys said something
