Originally posted by 92civicb18b1@Oct 13 2004, 08:08 AM
You can bore to 84 mm but the sleeves are gonna be pretty damn thin, I would reccomend about 82mm like 97CTR said.
It also depends on what you're doing, if it's going to be a relatively stock motor where you're not beating on it all the time, 84 is reasonable and will work fine. If your going FI, I wouldn't go over 82 on stock sleeves.
It's early and if I said something stupid and wrong just ignore it.
[post=402061]Quoted post[/post]
Originally posted by sohcbuilder@Oct 13 2004, 03:03 PM
werd ... depends on what your setup is compression, depends wether your going na boosted or nitrous ....... as far as bore'n it if your going turbo you might as well bore and sleeve it if your going all motor id bore it 81 and be safe
[post=402232]Quoted post[/post]
