spray all over the intake manifold, dont spray into the TB, spray around the TB,all over the manifold, and all the vacuum lines, also spray the brake Booster.
It is not that air is escaping elsewhere, it is sucking air from elsewhere, the idle should drop as you spray into the leak.
